New motor update
RE: New motor update
ORIGINAL: SOHCtimes2
Rofl...what a joke.
Guys its a super top secret engine! Why even post about your new engine if you aren't willing to tell anyone what's done to it?[&:]
ORIGINAL: David_K
Im sorry im afriad i cannot do that
because its still in the testing phase. IF you spend $25K on a motor you dont want anybody copying you
Elf makes the best brake fluid thats why i chose them as a sponser rather than motul
25k for an engine that **** better run off water or whatever fuel i put in it and run 1000+ hp while getting 30 miles a gallon but your right i wouldnt want someone to know my specs or what i built so they could build the same exact thing for 3/4 the price i would feel bad
well that good atleast someone has figured out some good heads because compared to others engine ours blow ***** but too bad he cant share the love ...maybe you will one day goodluck on getting the engine running properly hopefully youll see some better power numbers with those replacement parts
The secret is the heads like he's been saying. The cammer motor has badass heads to begin with. If you find yourself a pair of Ford GT heads, P&P them, slap them on our little 4.6 and add a little forced induction to the mix (because that's what those heads are designed for) and you'll make insane numbers with very little boost.
Edit: And you're both forgetting that's N/A 400 HP with only 5.3L of displacement... add some nitrous to that (which won't happen because it's made for auto x) and the numbers will get even higher, and fast. Think about it, he's making that N/A where our stock GT engines with 9lbs of boost barely make that same power. It's not always about how much power you have, you need to factor in potential.
Edit 2: David what class do you race in? Are blowers restricted? I know the Cammer motor is made to run N/A but even it will have something to gain from a bit (make that a ton) of boost
