transmission!
Old Nov 5, 2006 | 04:22 PM
PerformanceRed4.6's Avatar
PerformanceRed4.6
Default transmission!
i need a transmission badly. 125 shot of nitrous has about put an end to the ol t45. what do i need to replace it with....and what flywheel clutch etc. to go with it? thanks
Old Nov 5, 2006 | 06:00 PM
beastzilla02's Avatar
beastzilla02
Default RE: transmission!
thats why u dont use nitrous..so u dont have to spend 2grand on a transmission
Old Nov 5, 2006 | 10:52 PM
Zoie_daGT's Avatar
Zoie_daGT
I actually have the same prob. You have a few options. You could go TKO or T56. They are very strong but will require fabbing on your part. I am actually rebuilding my Tranny and getting Spec II clutch and alum. flywheel along w/ MGW shifter. Just do the research and find out what you think would be best for you.
Old Nov 5, 2006 | 11:41 PM
PerformanceRed4.6
i was thinkin bout just rebuilding my t45 but ive look at tko500 and t56, i dont kno which i should go with...maybe t56 and go with soem 4.30 gears in rear!
Old Nov 5, 2006 | 11:42 PM
ShadowDrake's Avatar
ShadowDrake
ORIGINAL: 97GT19
You forgot to say +1 post count. Great job posting useless information.
There's a couple of companies out there that sell re-manufactured T45s with beefed up internals... may want to pick up a mustang mag and look for the ad... they'll probably give you some money for your blown up tranny.
Old Nov 5, 2006 | 11:47 PM
Zoie_daGT's Avatar
Zoie_daGT
If it helps, I am getting my stuff done at Hanlon Motorsports. They work on T5s and T45s and have been helpful.
Old Nov 5, 2006 | 11:53 PM
djb1187's Avatar
djb1187
ORIGINAL: Zoie_daGT
I dont mean to sound like a *** or anything but you dont have to fabricate nothing. Everything bolts right up. With a t56 you dont even need a bell housing, just a driveshaft and cross memeber.
Old Nov 6, 2006 | 12:13 AM
David_K's Avatar
David_K
the TKO tranny will run you around $3500 for everything youll need
Old Nov 6, 2006 | 12:31 AM
djb1187's Avatar
djb1187
ORIGINAL: David_K
!!!!!!!Where did you get that price from, i was thinkin like 2000!
Old Nov 6, 2006 | 03:08 AM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: djb1187
ORIGINAL: David_K
Its only 1800 for the trans...
But then you really should replace the flywheel, and the clutch. And you need a new bellhousing... and depending on transmisison you may need a new yoke, might as well get an aluminum driveshaft too.
The swap is not cheap. If you do it barebones, aka order the 10 spline TKO 500 and keep your stock clutch (not smart) your still looking at about 2200 or so with shipping and all the BS (fluid etc).
I wouldn't say it will cost ya 3500, but I probably had close to 2500-3000 in it all said and done.
1800~ for the TKO
250-300 for the clutch (i think it was anyway)
200-250 for the driveshaft/yoke
150-200~ (?) for the flywheel
200-250 for the bellhousing
It all adds up. I would have to get my recipts to see the total, but above is a pretty good rough estimate.
