trouble codes
trouble codes
A tech on another msg board posted this - so i thought it'd be good to post here - might be a good sticky??
PCM Trouble Codes:
P0102 Mass Air Flow circuit Low Input.
P0103 Mass Air Flow circuit High Input.
P0106 EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.
P0107 EGR/BARO Signal circuit is Less Than Self-Test minimum.
P0108 EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.
P0112 Intake Air Temperature circuit Low Input.
P0113 Intake Air Temperature circuit High Input.
P0117 Engine Coolant Temperature circuit Low Input.
P0118 Engine Coolant Temperature circuit High Input.
P0121 In-Range Operating Throttle Position Sensor circuit failure.
P0122 Throttle Position Sensor circuit Low Input.
P0123 Throttle Position Sensor circuit High Input.
P0125 Insufficient Coolant Temperature to enter Closed Loop.
P0126 Insufficient Coolant Temperature for Stable Operation.
P0131 Upstream Heated Oxygen Sensor circuit out of range - Bank No. 1.
P0132 Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.
P0133 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1.
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0136 Downstream Heated Oxygen Sensor circuit fault - Bank No. 1.
P0138 Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.
P0140 Downstream Heated Oxygen Sensor circuit Faulty - Bank No. 1.
P0141 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0151 Upstream Heated Oxygen Sensor circuit out of range - Bank No. 2.
P0152 Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.
P0153 Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2.
P0155 Upstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0156 Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0158 Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.
P0160 Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.
P0161 Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0171 System Too Lean - Bank No. 1.
P0172 System Too Rich - Bank No. 1.
P0174 System Too Lean - Bank No. 2.
P0175 System Too Rich - Bank No. 2.
P0176 Flexible Fuel Sensor.
P0180 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0181 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0182 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0183 Engine Fuel Temperature Sensor circuit - Electrical fault.
P0187 Engine Fuel Temperature Sensor circuit.
P0188 Engine Fuel Temperature Sensor circuit.
P0190 FRP Sensor Signal Low.
P0191 Engine Fuel Temperature Sensor circuit.
P0192 Engine Fuel Temperature Sensor circuit .
P0193 Engine Fuel Temperature Sensor circuit.
P0222 Throttle Position Sensor B circuit Input Low.
P0223 Throttle Position Sensor B circuit Input High.
P0230 Fuel Pump Primary circuit fault.
P0231 Fuel Pump Secondary circuit Low.
P0232 Fuel Pump Secondary circuit High.
P0300 Random Misfire Detected.
P0301 Misfire Detected - Cylinders 1-10.
P0302 Misfire Detected - Cylinders 1-10.
P0303 Misfire Detected - Cylinders 1-10.
P0304 Misfire Detected - Cylinders 1-10.
P0305 Misfire Detected - Cylinders 1-10.
P0306 Misfire Detected - Cylinders 1-10.
P0307 Misfire Detected - Cylinders 1-10.
P0308 Misfire Detected - Cylinders 1-10.
P0309 Misfire Detected - Cylinders 1-10.
P0310 Misfire Detected - Cylinders 1-10.
P0320 Ignition Engine Speed (PIP) Input circuit fault.
P0325 A Spark Knock Occurred - Sensor Circuitry did not respond.
P0326 Spark Knock has not been sensed.
P0330 A Spark Knock occurred - Sensor Circuitry did not respond.
P0331 Spark Knock has not been sensed.
P0340 Camshaft Position Sensor circuit fault.
P0350 Ignition Coil Primary circuit fault.
P0351 Ignition Coil A Primary circuit fault.
P0352 Ignition Coil B Primary circuit fault.
P0353 Ignition Coil C Primary circuit fault.
P0354 Ignition Coil D Primary circuit fault.
P0355 Ignition Coil Primary circuit malfunction.
P0356 Ignition Coil Primary circuit malfunction.
P0357 Ignition Coil Primary circuit malfunction.
P0358 Ignition Coil Primary circuit malfunction.
P0359 Integrated Ignition On Plug failure.
P0360 Integrated Ignition On Plug failure.
P0385 Misfire Detection Sensor circuit failure.
P0400 EGR Flow Faulty.
P0401 Insufficient EGR Flow.
P0402 EGR Flow Excessive at Idle.
P0411 Secondary Air Injection System Flow Improper.
P0412 Secondary Air Injection System Control Valve Faulty.
P0413 Secondary Air Injection Solenoid did not change when activated.
P0414 Secondary Air Injection Solenoid did not change when activated.
P0416 Secondary Air Injection Solenoid did not change when activated.
P0417 Secondary Air Injection Solenoid did not change when activated.
P0420 Catalyst System Efficiency below Limit - Bank No 1.
P0421 Catalyst System Efficiency below Limit - Bank No 1.
P0430 Catalyst System Efficiency below Limit - Bank No 2.
P0431 Catalyst System Efficiency below Limit - Bank No 2.
P0440 Evaporative Emission Purge Control Solenoid Damaged.
P0442 Leak in Evaporative System Detected.
P0443 EVAP Canister Purge Control Solenoid or Valve Faulty.
P0446 Evaporative Emission Control System Vent Control malfunction.
P0452 Fuel Tank Pressure Signal circuit Input below minimum.
P0453 Fuel Tank Pressure Signal circuit Input above maximum.
P0455 Leak or Blockage Detected in Evaporative Emission Control System.
P0460 Fuel Level Input circuit malfunction.
P0500 Vehicle Speed Sensor fault.
P0501 Vehicle Speed Sensor fault.
P0503 Poor Vehicle Speed Sensor Performance.
P0505 Idle Air Control Valve System fault.
P0552 Power Steering Pressure Sensor Shorted to Power.
P0553 Power Steering Pressure Sensor Shorted to Power.
P0602 Replace PCM.
P0603 PCM has Experienced Power Interrupt.
P0605 PCM Read Only Memory Error.
P0703 Brake On/Off Switch Input fault.
P0704 Clutch Pedal Position Switch Input circuit fault.
P0705 Transmission Range Sensor out of Self-Test Range or Shorted to Ground.
P0707 Transmission Range Sensor circuit Low Input.
P0708 Transmission Range Sensor circuit High Input.
P0712 Transmission Fluid Temperature Sensor circuit Input Low.
P0713 Transmission Fluid Temperature Sensor circuit Input High.
P0715 Turbine Shaft Speed Sensor circuit fault.
P0720 Output Shaft Speed Sensor circuit.
P0721 Output Shaft Speed Sensor circuit.
P0731 Improper Ratio for First Gear.
P0732 Improper Ratio for Second Gear.
P0733 Improper Ratio for Third Gear.
P0734 Improper Ratio for Fourth Gear.
P0735 Transmission problems.
P0736 Improper Ratio for Reverse Gear.
P0741 TCC System Improper Mechanical Performance.
P0743 Torque Converter Clutch System Electrical failure.
P0746 Electronic Pressure Control Solenoid Performance.
P0750 Shift Solenoid No. 1 circuit.
P0751 Shift Solenoid No. 1 Performance.
P0755 Shift Solenoid No. 2 circuit.
P0756 Shift Solenoid No. 2 Performance.
P0760 Shift Solenoid No. 3 circuit.
P0761 Shift Solenoid No. 3 Performance.
70765 Transmission system problems.
P0781 1 to 2 Shift Error.
P0782 2 to 3 Shift Error.
P0783 3 to 4 Shift Error.
P0784 4 to 5 Shift Error.
P1000 OBD-II Monitor Testing Incomplete.
P1001 KOER Test Cannot Be Completed.
P1039 Vehicle Speed Signal Missing or Improper.
P1051 Brake Switch Signal Missing or Improper.
P1100 Mass Air Flow Sensor Intermittent.
P1101 Mass Air Flow Sensor out of Self-Test Range.
P1112 Intake Air Temperature Sensor Intermittent.
P1116 Engine Coolant Temperature Sensor is out of Self-Test Range.
P1117 Engine Coolant Temperature Sensor Intermittent.
P1120 Throttle Position Sensor out of
PCM Trouble Codes:
P0602 Replace PCM.
