pi swap
Old Nov 9, 2006 | 07:57 PM
droptoppony's Avatar
droptoppony
Default RE: pi swap
ORIGINAL: SXGT
If i did Heads, i would go with aftermarket, you can buy 370cfm heads , thats almost what DOHC does YUM
who has 370cfm 2V heads?
Old Nov 9, 2006 | 08:48 PM
demon_head's Avatar
demon_head
Default RE: pi swap
ORIGINAL: gt96stang
Ah, people please learn before you post. It has been found out that the heads are not the most restrictive part of the swap. The intake/cams are where most of the power will be picked up. Plus another 10 or so from swapping the heads which could be from the result in bumping the compression up.
+1 i've heard more than a few of these statements....usually the numbers i've seen are about 15-17 hp from the intake, 12-15hp from the cams usually around 10 or so for the heads. Someone on a tight budget can come out w/ some pretty decent numbers at a pretty good price if you just do intake/cams because the heads are the most expensive part of the swap.
Old Nov 9, 2006 | 09:52 PM
stang2000's Avatar
stang2000
Default RE: pi swap
If interested I have PI cams with the stock gears still pressed on out of my 00. $75.00 plus shipping.
Old Nov 9, 2006 | 10:14 PM
SXGT's Avatar
SXGT
Default RE: pi swap
ORIGINAL: droptoppony
ORIGINAL: SXGT
ive seen them for sale, $900 [:@]
Old Nov 10, 2006 | 01:31 AM
droptoppony
Default RE: pi swap
ORIGINAL: SXGT
ORIGINAL: SXGT
I doubt it! The highest flowing 2V head i have ever heard of was a SVO head with severe race port done to it....it flowed @ 280cfm
you probably were looking at pushrod heads.
Old Nov 10, 2006 | 08:13 PM
ripper's Avatar
ripper
Default RE: pi swap
Pi swap will def give you more power. BUT you will have 10:1 comp that will limit you if you ever decide to supercharge. BUT lol nos loves compression . Stage 2 cams (i think not positive) wont clear with the flathead pistons either. If you like nos def do the swap you wont be sorry
Old Nov 10, 2006 | 08:25 PM
droptoppony
Default RE: pi swap
ORIGINAL: ripper
We don't have flathead pistons...they are 9cc dished.
Old Nov 10, 2006 | 08:53 PM
beastzilla02's Avatar
beastzilla02
Default RE: pi swap
if u do a pi swap on a sn95...it will run better times than a new edge...why is that?? ive heard that from numerous people.
Old Nov 11, 2006 | 05:03 PM
steedondubs's Avatar
steedondubs
Default RE: pi swap
ORIGINAL: Hash06
the heads don't need to be changed the only way you get power out of them is the compression raise. i am going to get crower stage 1's and the pi intake
[sm=wakeup.gif]
Old Nov 11, 2006 | 10:02 PM
droptoppony
Default RE: pi swap
ORIGINAL: 97GT19
from the compression jump.
