Stock times??
Stock times??
just wondering if any of you guys went to the track before modding your stangs what were yalls times or do you know of any stock times the reason im asking is because i seriously think there is somthing wrong with my car and i cant figure out what or am i just parranoid i took my stock 98 cobra to the track 3 times and ran between 14.48-15.1 now it may be my driving but i just cant figure it out i dont think im a bad driver i launch fairly well and hit the tree just fine any input thanks
RE: Stock times??
at first i was spinning alot but i controlled that i didnt mention that my very first run was lol 15.8 i think that spinning pretty much all first gear and no shift quickly and most of the time smoothly
RE: Stock times??
Give us the 60ft time on your slip. That is where most of the time is lost. Im willing to bet your 60ft's are 2.2+. If you were to get that down to 2.0 or lower, you would be running 14.0-14.1. What was your speed? What was your 1/8mi time?There are many factors in this. Is your track Hi altitude? Just give us some more info
PS Your reaction time off the tree has nothing to do with your ET
RE: Stock times??
Yea bro thats horrible times. What did your 60ft time look like? If the 60ft is ok then you definitely need to check your car because thats too slow. A buddy of mine at the track his first time with just exahust on his 2000 GT ran a 14.2 with a 2.460ft time. That same guy was beat by my other buddy with a 97 Cobra with an o/r x-pipe nothing else. So definitely check your 60ft time.
RE: Stock times??
ORIGINAL: 98cobratx
RE: Stock times??
im going to the track friday with a few mods done so ill see then so any advice on driving i mean when i try to shift too fast my gears grind like no other is that okay should i force it or what mainly from 1st to 2nd is when it has happend
RE: Stock times??
AHHHHHHAAAAA. I knew it. In no way do i mean to be rude, but those 60ft times are horrible. Just a fact. Heres a rule of thumb. For every .1 sec you take off your 60, take .2 off your ET.
So if you take .4 off your 60,(thats .8sec off your ET for all you math whizzes) you will be running 14.0-14.2 everytime. Work on it man. Find the best way to launch, or just screw it and get some drag radial tires.
RE: Stock times??
ORIGINAL: 98cobratx
