Premium fuel
Old Nov 11, 2006 | 08:00 PM
  #31
Dan04COBRA's Avatar
Dan04COBRA
Default RE: Premium fuel
ORIGINAL: ShadowDrake
ORIGINAL: goldeneagle_10
akelemecz... it just seems with your posts you come here and act like you know everything there is to know about mustangs and act like noone else has a clue to what they're talkin about. Sure there is incorrect info sometimes, but there are plenty of guys on here that know what they're talkin about. All I'm saying is, you'll make alot more friends when you quit calling people stupid and cut and paste guys. I just get tired of seeing posts like that.
He's just a troll, thus the reason I have him on my block list Don't bother arguing with ignorant people, they'll drag you down to their level and beat you with experience
[IMG]local://upfiles/1627/73A829E9AEF648AD9B13CE50B386815F.jpg[/IMG]
Old Nov 11, 2006 | 09:18 PM
  #32
cesar5571's Avatar
cesar5571
I used to run 93 in my stock V6, but noticed no difference. It just ate up a lot of cash.
My Mach 1 requires 91 at a minimum, but I can usually only find 87, 89, or 93 locally. I use 93 and it works fine. Not sure if going higher would make any difference unless mods required it. I would recommend going with whatever the manufacturer recommends and go from there.
Does anyone know if the octane booster they sell at the store helps improve performance?
Old Nov 11, 2006 | 10:29 PM
  #33
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Octane booster is not going to do much if anything. They do not really increase that octane in the amount that they claim.
Old Nov 11, 2006 | 10:44 PM
  #34
oxfordgt's Avatar
oxfordgt
Octane booster is for ricers cause they think it makes their cars faster like stickers and wings do. Most octane boosters will bring 89 to 89.3.
Old Nov 11, 2006 | 10:51 PM
  #35
geetee03's Avatar
geetee03
higher octane gas is less combustible than lower octane. if you have a stock tuned gt you wasting money, if the higher octane does have more additives it would be cheaper to buy a fuel system cleaner once or twice a year. plus the oil companies don't need the extra cash!
Old Nov 12, 2006 | 01:19 AM
  #36
djb1187's Avatar
djb1187
i vote run 87 stock
gotta tune run 93
when the price is right, run 93 every now and then. But i ran 87 in my GT all the way untill i got my xcal and bumped the timing up.
Old Nov 12, 2006 | 02:11 AM
  #37
1fast50's Avatar
1fast50
so im guessing the 1996-1998 cobra engines dont really need the "91" octane fuel?
Old Nov 12, 2006 | 12:51 PM
  #38
JD1969's Avatar
JD1969
ORIGINAL: 1fast50
Whats the compression? If it's over 9.5 then 91 octane is a good idea
Old Nov 12, 2006 | 01:16 PM
  #39
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: JD1969
ORIGINAL: yetihairball
Argh...if your car is tuned for 87, which it is if it's a GT, then you should put 87 octane in it. 93 octane will not burn thoroughly in your engine and will likely ignite in your exhaust pipes. But just think of all the liquid fuel that is likely to STAY in your engine, sticking to and coating internals since it's not burning completely.
It's my undestanding that higher octane is good for your engine every now and again to clean stuff out, but running it all the time will only cause problems and will degrade the performance of your engine. If you want to run 93, get it tuned for 93.
93 will not ignite in the pipes, it won't stay in your engine in a liquid form and coat things and it is not harmfull to run in your car. You will not see a gain from running it unless you advance the ignition timing and even then only to a point. All higher octane really does is resist pre-ignition, this resistance allows higher compression, more timing, more boost, ect. It is not a cleaner fuel always, it won't clean your engine. Most of the detergant advertising is just that....advertising....always take advertising claims with a grain of salt.
If anyone is interested there is a good sticky in the Street/Strip section that explains octane and what it's effects are.
+10000
93 is not any cleaner, does not clean your engine, and will not improve performance unless you have a higher octane tune or your car calls for it from the factory.
Complete waste of money on a stock car.
Old Nov 12, 2006 | 01:21 PM
  #40
nanaki's Avatar
nanaki
Retired MF Moderator
wow. it was explained so many times that higher octane means dick, but some people don't learn. only run it if you're tuned for it, or if your non-tuned car pings on 87, just bump it up a grade.
