Spec Clutches..
Yeah I think I am going to get the SPEC1. Not only is it cheaper but I agree that the 3 and probably the 2 would be a bad idea for daily drives
Now I have to find out if autozone carries TB retainers bacuse I dont feel like ordering one and finding out that I dont need one
Thanks for the help all,,
Also what are the chances I would need my flywheel machined? Or is it good to have it done just for good measures?
would you all agree that i should most definantly get the steeda clutch adjuster kit with the QUAD.. or since im getting a SPEC1 and this is my daily driver, i would have no use for it and not worth the 100$?
the driveability of it..
stage 1: there is some play in the clutch. you let off the clutch a little and start to feel it pull, it doesn't grab right away. you could ride the clutch if you wanted to.
stage 3: there is NO play in the clutch. you start to let off the clutch and when it grabs, it grabs hard. there is no riding the clutch in a stage 3....
stage 2 would be somewhere in the middle.
so by grabbing hard it'll b like learnin how 2 drive stick again??...when it grabs hard doesnt that get the power to the ground better...and how much would a shop charge for a clutch install?
ORIGINAL: RollinThunder
