drag radial
drag radial
so question for you guys which tire would you prefer for a DD and maybe some track use but i do have slicks also....so i got
Mickey Thompson 275/40/17
or
BFG 315/30R/18.....
tell me what you think...i got a kenne bell 2.1 comin soon
i am really set on a drag radial but which is better for daily use and still get great traction....oh and one more thing im kinda dumb when it comes to "car" tires..im use to 44's and big *** mud tires cuz thats what i grew up around. so can someone explain the difference in 315/30 and 315/40
or
BFG 315/30R/18.....
RE: drag radial
Heres tire sizes in a nut shell. The first number 315, means that the tread area across is 315mm wide. The second number 30 or 40, is a precent of the first number, so for a 315/30, means that the sidewall should be 94.5 mm tall. So for the 40 series tire it would have a 126 mm sidewall.
-P.
PS: Go with the mickey thompsons, theyre stickier but the sidewall is a lot flimsier and on some of em you have to run tubes.
-P.
RE: drag radial
Sidewall makes a HUGE differance in drag racing. A taller, softer sidewall will absorb the "shock" at launch and keep the tire planted. Niether of those sizes are ideal for drag racing but between the two I would go with the M/T.
RE: drag radial
ORIGINAL: djb1187
good question...i was considering 275/40/17
