steeda tri ax install question
i have a question is it better to install a steeda shifter with the gaskets they said u dont need to use silicone with the gaskets and it is more easy to do the install with gasket any comments on this
RE: steeda tri ax install question
I bought the gasket and forgot it at my apt when i went to install the shifter so I ended up using silicon. Some ppl have had problems with the gaskets, but Ive never heard of a problem with the silicon. I would use the silicon if i was you.
ORIGINAL: eventer289
leaks
ORIGINAL: djb1187
i put my stocker back on without putting any gasket on it because i was being lazy[sm=chairshot.gif]...whats the risk of running it with no gasket?
yeaqh i got the steeda tri ax shifter and i didnt research enough and i didnt put in the gaskets or the silicone. Noise is annoying as hell. I was unaware of the leaks though.
Sounds like silicone is the way to go. What is a good brand and where can i get some.
