Break-in Instructions for Motive 4.10's
Old 11-16-2006, 09:45 PM
Crimson Fox
Crimson Fox's Avatar
Default Break-in Instructions for Motive 4.10's
Anyone have the break-in information in a pdf or word doc?
Thanks.
-Nicholas
Crimson Fox is offline
Old 11-16-2006, 09:46 PM
trance565
trance565's Avatar
Default RE: Break-in Instructions for Motive 4.10's
ummm, just dont drive hard for 300-500 miles, like a clutch i think.
trance565 is offline
Old 11-16-2006, 09:54 PM
beastzilla02
beastzilla02's Avatar
take it east for abou 500 miles.
beastzilla02 is offline
Old 11-16-2006, 10:02 PM
Crimson Fox
ok, I heard that there was a weird break-in procedure so I figured I would ask.
You are supposed to drain and refill the diff after the first 500 or so right?
-Nicholas
Old 11-16-2006, 10:37 PM
trance565
trance565's Avatar
dont think my brother did, but it would probably help.
Old 11-17-2006, 04:02 AM
eventer289
eventer289's Avatar
ORIGINAL: Crimson Fox
-Nicholas
Its about 500 miles to fully break them in. When they are first installed, drive for about 15-20 miles at 55 mph or lower and then let the car sit for 30 min. Repeat about 3-4 times until you get to 100 miles. This is called heat cycling and it is necessary to keep the metal strong. If you romp on them when they are first installed and dont heat cycle, you run the risk of softening the metal and running into gear whine problems. People will tell you not to worry about breaking them in and to just let 'er rip, but don't listen to them. If you really want your gears broken in well, make sure to heat cyle, don't go over 55 mph for the first 100-150 miles or so, take it easy on them for the first 500 miles. When you get to 500 miles, change your gear oil. I'd reccommend Royal Purle. It has the friction modifier already added (its necessary for the clutches in the differential to work properly). Changing your diff fluid is really easy. It took me about an hour and a half with the help of a friend (most of the time I was cleaning the diff cover and the bolts and waiting for the gasket maker to set up). After all that, let those gears rip. What gears are you putting in. I have 4.10's and I was AMAZED at the difference.
eventer289 is offline
Old 11-17-2006, 01:36 PM
98MustangSTL
98MustangSTL's Avatar
Drive it for about 10 min easy, and then romp on it.
98MustangSTL is offline
Old 11-17-2006, 01:40 PM
Kadence
Kadence's Avatar
ORIGINAL: 98MustangSTL
+1, my friend did that, worked fine, well there is this whining noise...
Kadence is offline
Old 11-17-2006, 04:56 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
There is no mileage break in.
3 heat cycles. Drive the car like a NORMAL person for 20 mins. Stop, let the car cool for 20 mins, repeat twice more and beat the car to death.
There is no mileage break in period. None, nill, notta, zero is the hero break in mileage my bunghole.
Enjoy it.
Dan04COBRA is offline
Old 11-17-2006, 07:33 PM
MarineNCOIC
MarineNCOIC's Avatar
I would still play it on the safe side... you might pay for it in the end. 500 miles easy driving, then change the fluid. Do a couple heat cycles like others have said. It sucks, but its well worth the peace of mind in the end.
MarineNCOIC is offline
Quick Reply: Break-in Instructions for Motive 4.10's
