??Transmission??
RE: ??Transmission??
ORIGINAL: mustangzrx
I have a 2003 GT Vert with a 5-speed. Is my tranny a TR3650 also?
Thanks in advance,
mustangzrx
ORIGINAL: blstoff
TR3650 = 5 speed
4R70W = automatic
TR3650 = 5 speed
4R70W = automatic
Thanks in advance,
mustangzrx
ORIGINAL: blstoff
^^^^yes you do have a Tremec 3650, i believe they made the switch mid 01?
Yes . mid 2001 - 04
Thanks in advance,
mustangzrx
ORIGINAL: blstoff
TR3650 = 5 speed
4R70W = automatic
TR3650 = 5 speed
4R70W = automatic
Thanks in advance,
mustangzrx
Yes . mid 2001 - 04
Appreciate it.
mustangzrx
Any one know the cut off? ours was built 02/01 I am guessing that is about mid -year since they start building around august for the next year? does the trannt say T45 or TR3650 physically anywhere on it?
Thanks Keith
Thanks Keith
Look at your speedo sensor. If it comes straight out and then has a 45 degree elbow I believe it is a T45 if it comes out from the tranny at an angle it should be the 3650.
I think that is the right way round
Cooper
Cooper
Just found this in the trans. tech area;
"The Mustang GT in 2001 had both the T5/T-45 and 3650 Transmissions. Check your driver's door for a sticker and look under "TR" for a "K". If you have a "K" then you have the 3650 Transmission."
Checked my door sticker and I have the K
