modular?
Old Nov 19, 2006 | 02:17 AM
handyandy's Avatar
handyandy
Default modular?
What does modular mean?
Old Nov 19, 2006 | 02:19 AM
gsxrstang69's Avatar
gsxrstang69
Default RE: modular?
Basically means that parts are interchangale between applications.
monkeydude3's Avatar
monkeydude3
In regards to the mustangs, it's the type of engine the GTs, mach 1s and cobras use.
I think it's because so many parts are similar between the 4.6s, 5.4s, SOHC and DOHC and some are interchangeable... but the big thing is they are all on the same core design
Old Nov 19, 2006 | 02:21 AM
handyandy's Avatar
handyandy
Still don't really understand. I know my GT has a "Modular", but what do you mean interchangeable?
Old Nov 19, 2006 | 02:24 AM
xxkazp3rxx's Avatar
xxkazp3rxx
Ford Modular engine
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Ford Modular V8
Also called: Ford Triton V8
Ford Triton V10
Lincoln InTech
Manufacturer: Ford Motor Company
Production: 1991–present
Predecessor: Windsor V8
385 V8
Class: SOHC/DOHC V8/V10
Engine: 4.6 L (4601 cc/280 in³)
5.4 L (5409 cc/330 in³)
6.8 L (6761 cc/415 in³)
Similar: Ford Triton engine
Jaguar AJ-V8
Chrysler PowerTech V8
Ford/Yamaha V8
GM Premium V
Mercedes-Benz M113/M115
BMW M62/S62
BMW N62
Nissan VH
Nissan VK
Toyota UZ
The Modular engine, or "mod motor" as it is often referred to, is Ford Motor Company's modern overhead camshaft (OHC) V8 and V10 engine family. It gradually replaced the Windsor small-block and 385 big-block engines over several years in the mid-1990s. The engine is modular in that it can be adapted to V8 or V10 with a variety of 2-valve and multivalve heads. It is used in Ford trucks, (called the Triton) in Lincolns (called Intech) and in Ford and Mercury cars. In 2004 Ford introduced a 3-valve SOHC with a Variable Camshaft Timing system, this engine will eventually phase out the 2-valve SOHC, although it has replaced a 4-valve DOHC engine, at least temporarily, in the Lincoln Navigator.
Old Nov 19, 2006 | 02:26 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
ORIGINAL: gsxrstang69
Huh???
What "modular" means to me is it's got coil on plug...
gsxrstang69
hahah i was just about to post that
2000GT4.6's Avatar
2000GT4.6
All of fords OHC V8 engines have interchangable parts, and are based on the same basic design.
The 4.6L in the trucks is basically the same design as your 4.6L. The 5.4L shares the same basic setup and some parts with the 4.6L.
This saves ford money, as they don't have to produce 50 different types of heads/blocks/cams etc etc for their engines.
Old Nov 19, 2006 | 02:27 AM
2000GT4.6's Avatar
2000GT4.6
ORIGINAL: mikev08826
Huh???
The term modular has absolutly nothing to do with the coil on plug ignition setup.
Old Nov 19, 2006 | 02:31 AM
korn253's Avatar
korn253
ORIGINAL: 2000GT4.6
Huh???
+1, not all modular engines have a coil over plug setup
