Clutch clang
Old Nov 21, 2006 | 04:34 PM
lizzyfan's Avatar
lizzyfan
Underboss
Default Clutch clang
This only happens when car sits overnight. When I first start off and press clutch in, there is like a metal clanging noise. After about 2 to 3 minutes noise goes away. Don't have a clue!!!!! I have a King Cobra clutch which was put in a few months ago.
Old Nov 21, 2006 | 07:44 PM
lizzyfan's Avatar
lizzyfan
Underboss
Default RE: Clutch clang
bump
Old Nov 21, 2006 | 07:49 PM
Boltt's Avatar
Boltt
Because it only happens when its cold, im going to guess there's too much slop somewhere. Gears, maybe bearings? When metal heats up, it expands, thus fixing the noise. I cant say where, but it sounds like too much backlash or slop somewhere.
Old Nov 21, 2006 | 07:51 PM
lizzyfan's Avatar
lizzyfan
Underboss
Seems to come from front of car, so I know it's not bearings. I wonder if it's the clutch cable being to loose causing play or slop so to speak?
Old Nov 21, 2006 | 08:00 PM
Boltt's Avatar
Boltt
Well you do have bearings inside the transmission, so it could be them. Although bearings tend to make a whizzing sound, not a clanking, unless its a ball bearing and it completely ripped apart. But warming up the engine wouldnt help that lol. Clutch cable being loose would just make the clutch slip. If its slipping, then there you go.
Old Nov 21, 2006 | 08:04 PM
lizzyfan's Avatar
lizzyfan
Underboss
ORIGINAL: Boltt
No, not slipping at all.
Old Nov 21, 2006 | 08:09 PM
Boltt's Avatar
Boltt
Pinpoint the sound to within 6 inches. If you can, lift the car on a jack and listen under the car. That will be your best bet if you're insisting on self-diagnostic.
Old Nov 22, 2006 | 02:00 AM
St4ng07's Avatar
St4ng07
GO through all the little things first before, looking at bearings in the trans. Which, correct me if im wrong but arent there only two bearings? Id, check tranny fluid, check cable (using 2 finger test), and go from there.
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Sep 30, 2015 10:13 AM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
