sub frame question
Old Nov 23, 2006 | 09:08 PM
dvs_03gt's Avatar
dvs_03gt
Default RE: sub frame question
what kind of differences will you notice with these welded in?
Old Nov 23, 2006 | 10:45 PM
JJ03MustangGT's Avatar
JJ03MustangGT
uum i didnt notice a big difference. less wheelhop, easier to do a burnout, and chirp 3rd. better power distribution for the strip
Old Nov 23, 2006 | 10:49 PM
JJ03MustangGT
the main thing i can say is not to always look for the biggest improvement alone but how much it helps in the long run. its kinda like gettin headers and exectin a full exhaust. you may not notice it at first but when you add springs, CA, and all the other suspension goodies.
Old Nov 23, 2006 | 11:00 PM
stang2000's Avatar
stang2000
I'd recommend doing it right.
You can get the extreme matrix and jacking rails. If I could find just the jacking rails, I'd add then to my current setup, but I can't seem to find just the jacking rails to add on. They also have just the double cross subframe connectors also with the seat brackets.
http://www.v8power.com/cat--Mustang-...ors--subf.html
Old Nov 23, 2006 | 11:04 PM
code3GT's Avatar
code3GT
Mustang Nazi
Come on by my house, we can take the car to a buds shop and Git-R-Done.
Old Nov 23, 2006 | 11:11 PM
dvs_03gt's Avatar
dvs_03gt
how are these?
http://www.v8power.com/item--Enginee...-KBP29550.html
Old Nov 23, 2006 | 11:14 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: dvs_03gt
how are these?
Man, you are going ultra high dollar. Unless you are doing CRAZY HP & TQ, the cheapies will work well. I recommend the ones with seat brackets....makes it easier to have them bolted on to keep everything straight while they are being welded. Just my .02
Old Nov 23, 2006 | 11:18 PM
99gtstang's Avatar
99gtstang
Trying to get r done!
Having problems since springs went on to much tire spin[&:]
Thanks for the help guys
Old Nov 23, 2006 | 11:24 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: 99gtstang
The sub-frame connectors will help a little but not alot with sub-frame connectors. They just keep the body and frame from flexing under heavy load. If you want help with traction, get some upper/lower CA's.
Old Nov 23, 2006 | 11:32 PM
99gtstang's Avatar
99gtstang
ORIGINAL: code3GT
ORIGINAL: 99gtstang
I am already buying those... been researching trying to decide from MM, STEEDA, UPR, or Some Adjustables (Because back end sits .5 inches higher) So not all weight is transferred at WOT and the spinning will start, But from what i gather there worthless on street only for jacking up and giving room for slicks.
