sub frame question
ORIGINAL: 99gtstang
I am already buying those... been researching trying to decide from MM, STEEDA or Some Adjustables (Because back end sits .5 inches higher) So not all weight is transferred at WOT and the spinning will start, But from what i gather there worthless on street only for jacking up and giving room for slicks.
ORIGINAL: code3GT
The sub-frame connectors will help a little but not alot with sub-frame connectors. They just keep the body and frame from flexing under heavy load. If you want help with traction, get some upper/lower CA's.
ORIGINAL: 99gtstang
Trying to get r done!
Having problems since springs went on to much tire spin[&:]
Thanks for the help guys
Hey Code, since you're on the subject...Are these any good? I haven't had anyone give a straight answer to this very simple question yet.
ORIGINAL: JJ03MustangGT
my girlfriend took hers to our friends muffler shop, and i did my own. pretty simple i thought. and yes its a very straight forward install.
ORIGINAL: code3GT
I run the non adjustable upper/lowers. Do some more research...my opinion is you are gonna spend more money than you need to in order to accomplish the same outcome.
ORIGINAL: 99gtstang
ORIGINAL: code3GT
ORIGINAL: 99gtstang
ORIGINAL: stang2000
I've got the kenny brown sub-frame connetors(when they were available at the time) with the seat brackets. I bolted them on plus welded them for extra strength.
Will get ones with seat brackets for sure
ORIGINAL: MustangMagic
Weilded Subframe Connectors by Max Motor Sports. Cost: $109 for the connectors $70 install.
Well worth the money.
[IMG]local://upfiles/54014/C331B7E89C8C4B96A3835EF6F74A477D.jpg[/IMG]
Thanks
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mrappe
Sep 26, 2015 10:16 AM
