Engine miss
Old Nov 23, 2006 | 03:58 PM
umpyre32's Avatar
umpyre32
Default Engine miss
98 GT that sat for couple of months. 170000 miles. Had a miss and I replaced plugs and wires. It got better but still has a slight miss and mechanic could not find anything in the computer and suggested running injector cleaner thru it, which I am. Can anyone tell me what the STOCK flow pressure is for the fuel injectors. I may pull injectors and take them to be cleaned, but I am also thinking of changing the injectors and the fuel rails. Summit Racing has injector pressure from 19 lbs. on up. How far can I go on the injector pressure and how will the above effect everything?
Thanks
Old Nov 23, 2006 | 04:02 PM
JJ03MustangGT's Avatar
JJ03MustangGT
Default RE: Engine miss
the only thing i can tell ya is that i work on planes, when we check injectors, if shop air doesnt fix the problem, then we replace em. so inspect em and go from there
Old Nov 23, 2006 | 04:23 PM
umpyre32's Avatar
umpyre32
Some of the carb shops have a machine that injects cleaner fluid thru the the injector in high presure pulses something like a waterpik(teeth). I've got a couple of friends who had good luck with this.
Thanks
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Gabe_mlcc
Sep 7, 2015 11:56 PM
Sep 1, 2015 08:16 PM
