forged parts
forged parts
i want to build my motor that that it will b able to hold more boost than 8-10 lbs when i super charge it. if i get al forged parts will it give me more power just by getting new internals or does it just make the motor stronger?
RE: forged parts
Forged pistons/rods/crank is just for strength. However, folks usually have the block/crank "blueprinted" as part of the build, which will decrease heat and increase power (a little).
BTW - you don't need a forged crankshaft unless you're going over 500 SAE hp
Also, if you're building a block to s/c, you have the opportunity to change your compression ratio. Many people will drop compression a little bit to allow for higher boost. There are many different opinions on which way to set it up, and it depends a lot on how you plan to drive the car (e.g. power vs. reliability).
RE: forged parts
ORIGINAL: jacrockett
If your goal is between 500 to 600 rwhp... Nodular Crank is the way to go. Thats what I'm getting.
09-25-2015 06:58 PM
