Shiftlight
RE: Shiftlight
you dont need an adaptor. get the raptor and call it a day. best shift light out plus its small and meggga easy install. just go on www.raptorperformance.com and buy it from there and read the install. goes through everrything. you cant mess up.
RE: Shiftlight
Crimp on connectors never work. Slice the wire coating off. DON'T CUT the wire, just remove the coating about 1/4 inch-3/8, split the wire in the middle, like making a hole between the wires, slide the raptor wire through the hole, loop it around and bam, easy as pie. It's a bitch to try and cut those wires and re-splice, since there're not much room to play at the ECU.
Oh yeah I've got the raptor as well. Works great and no, you don't need a tach adapter. 1 wire on the raptor taps into a tach wire at the ECU, 1 power wire, and then 1 ground wire. Very easy.
Pic below is my car. Look at the dash. I mounted my light right in the middle of the cluster. It covers the bright light symbol, but who cares about that, lol
RE: Shiftlight
ORIGINAL: stang2000
I'm not real crazy about just pulling back the insulation and wrapping the wire around it. I guess it would be fine if you tape the hell out of it.
RE: Shiftlight
ORIGINAL: eventer289
Anybody know where to find the "crimp on" connectors the article mentions?
About how long does it take to install this?
I installed my Raptor on the A-pillar near the top, just above eye-line. You wouldn't know it was there unless you are looking for it. I put it there b/c it kept my eyes up on the road and, let me tell you, when that red light goes off, you know it.
Here's some pics
