HELP CEL p1506 Idle error
He i just install a new tb yesterday, and i made a post about wierd idle, well today the check engine light went on, and i got it scanned the code it "Idle air contol overspeed error" p1506. What is that and what is broken
RE: HELP CEL p1506 Idle error
This is either your IAC or your TB. What I can suggest is make sure there are no air leaks, re-line up the gaskets and make sure you tightened everything up. Pics would be good too so we can see if there is anything obviously wrong visually.
Good Luck,
E.
Good Luck,
E.
I was thinking its the iac, beacuse hte cleaned the plenum with tb cleaner, and mb some got on the iac. I am going to clean the iac, and if that dosent fix it im gonan put the stock tb back on
