Changing radiator
Changing radiator
I am swapping my radiator out tomorrow and have some questions about the job. Is it as simple as draining the coolant, removing the radiator shroud, removing the fan, removing the upper/lower radiator hose, undoing a few bolts, and pulling the radiator out? Is there anything I missed here?
RE: Changing radiator
ORIGINAL: phantom1
don't forget to recharge the flux capacitor.
ORIGINAL: randy78045
Make sure you replace the coolant...
the place I got the radiator from said it is off of a 99 Cobra. This radiator has 2 extra holes in it for what looks like the transmission cooler line hookups. Can i just find something to plug these up? and if so, do you know what size plugs i'd need?
Those brass fittings are threaded on the inside
