Are Eibach Sportlines too low for LT Headers? Any Pics?
RE: Are Eibach Sportlines too low for LT Headers? Any Pics?
I have the Pro kit with Tokicos and I have to go VERY slow over speed bumps. If I had gone with Sportlines I would have to park at the entrance of any parking lots with speed bumps and walk the rest of the way!
What do you guys think are a good set of springs to lower it a little bit so I don't scrap the LT Headers. And not make any other mods to the suspension.
ORIGINAL: burn64
If you swap in some of the polyurethane busings when you do the install, it will probably help you out too. If I recall correctly, they are stiffer and don't compress as much, thus making the car ride a tad bit higher. You will still be lower than if you went with the Pro-Kit, but not as low as with the Sportlines alone.
ORIGINAL: blstoff
I have the pro-kit w/ LT's & sometimes it scrape's on speed bumps . especially w/ more weight in the car . if you install sportlines , I would stay away from speed bumps . and yes , you should get c/c plates
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
