Supercharger ?'s...
#21
RE: Supercharger ?'s...
i am not saying that there will be a huge difference, im just saying that each will have their own characteristic at the same rpm's including power. example, p1sc - novi 1000 both are the entry level, intercooled 8-10 psi, same car will make good power but from what i have done and seen the p1sc has been stronger for a longer rpm range. the power that is put into the motor is getting fed the same but the setup is not. its like trying to compare a stage 2 comp cam and a stage 2 VT cam. both give great power but where and how the power comes on will be different from car to car.
#23
ORIGINAL: stang2000
I will tell you , I have my new dyno sheet and my P1SC with a 3.6" pulley running around 9psi is pulling good all the way through the powerband from about 2k to 6000k.
I make boost from around 2500rpms, full boost around 3800-4k, and it stays pegged at 10psi till I shift. Could easily have it tuned for more power since its actualy tuned emissions legal for NY right now.. but I dont want to push my stock block/transmission anymore than it already is.
my thing is a lot of people are HUGE fanboys of one manufacturer or another.. but when you ask them to explain why one unit makes x hp at 10psi, but the unit they like makes sooo much more than that at 10psi with the same cooling method and RPM range (even people who dont have them), they cant.. because its mathmatically impossible if everything on the motor, tune, cooling, and the PSI is the same.
#24
ORIGINAL: HaV
I dont doubt that one bit. Procharger is the way to go if you want to one stop shop.. the fact that they all come with the intercooling pipeing and stuff makes it really convinent, but htey do run a bit more pricey. Hell, mine isnt even intercooled, just the meth/water injection kit.. same effect different method. Would love to have IC + the snow kit.
ORIGINAL: stang2000
#25
its about moving the volume of air at x amount of psi. you are right, the "math" is all there. if 2 superchargers are pushing the same boost it is the one pushing more volume that will make more power. i am not wanting to start an argument, nor am i trying to have a bias opinion. but it takes more than psi to make power. the larger the volume and how efficient it is at moving it will show in the numbers. sure a p1sc,novi 1000, or what ever your preference may be can make 10 psi but what is the volume?,how efficient are they at that volume?
#26
Its a Snow Performance kit (the people who make it). They arent that expensive, around 400 or so and they are easy to use.
Its a little pump controler that works off my boost level. You can get a more expensive one that will run off of other sensors, but mine is tied in to boost (infact my boost gauge is T'd off of it as well). Its adjustable to its spray rate and it sprays any time I am making over 2psi of boost.
These kits arent what you think when you hear methonal injection. It acutaly uses windshield wiper fluid. The little bit of methonal in it (have to use -20 or better fluid) will burn under compression acting as a mild octane boost (which helps with a boosted motor) and the mix of hte water/meth is much cooler than the compressed air temp coming off the charger. It keeps the air temps way down and also helps keep the cylander cool. It basicaly acts the same way as an intercooler but with a very mild octane boost. Works great on NA cars or boosted since you can run more timing/boost w/o detonation.
It did not come with the vortech and you have to tune with it. It was actualy on the car when I bought it (bought someone else project.. which is now my project.. gotta love having a great base to start from [8D]) Its definatly something you would want dynotuned.. it would be a good idea to do it at the same time as a charger/turbo/etc.
Here, I'll throw a pic up with it. I circled hte pump in red (you can see the excess tubing for the boost gauge tied into it as well there), and the location where it sprays into my air intake in blue. I love the thing for the cost and effect it has. Some people hear meth injection and think along the lines of nitrous.. its really more of a cooling factor + octane boost where nitrous really just aids the rate your current fuel burns a LOT making its combustion more powerful. A meth kit will not blow your motor.. However it will KEEP your motor from blowing.
#27
ORIGINAL: sweet2kstang
#28
at least we have an understanding to each other. i know what you are trying to get across and i am just getting my point across of why and how. youre right about how they are the same in most aspects but there will alway be a difference even if its just a small amount. as far as a bias opinion i am a little stuck on the ati for the centri setup but i also respect everyone elses opinion on their favorites and why it is.
#29
So your snow performance kit (injection) works just as well as an intercooler, but cheaper basically? I like the way that works, and sounds ALOT less complicated to install..
#30
kits will have an intercooler if plan on running more than 6psi. you will have to make sure if run more than 6psi w/o intercooler that the injection system has enough to keep system cool. otherwise you will push the limits on the bottom end.
