speedo fix
RE: speedo fix
Ouch.. sounds like you have gears. For an 00, go get an SCT Xcal2. You can also go to dallasmustang.com and pick up a speedcal, but you would be better off getting a tuner. The speedcal is an easy install (I did a write up on it for this site actualy... its very simple), but if you plan on doing any mods the tuner is a much better investment.
How does the car run? Seem like it takes off like a bat out of hell, or just normal feeling for a car? The guy could have swapped in the old gears..
or I could just be wrong and your speedo is jacked. Lol.
RE: speedo fix
ORIGINAL: Brandons98GT
Well it has alot of other mods, and so far everytime i put the pedal to the floor i end up sideways so i would say the gears on not stock how can i find out what they are.
You have a 00 not a 98 right? your screen name keeps messing with my head
//easily confused [&:]
RE: speedo fix
Just a fair warning, I know on all stangs up to 97 (and Im pretty sure on the 98's.. thats the year they put in the digital odometer and ive never owned one so dont know for sure), that you HAVE to use a speedcal or speed gear. The speedo is not adjustable with a tuner/flash. You have to hardwire it or change hte gear itself.. and if you go anymore than 3.73's the gears STILL wont be accurate. 99+ you can for sure use a tuner to adjust the speedo though.
RE: speedo fix
ORIGINAL: doughboy4.6
speedo gear?
speedo gear?
Like I said, 97 back (and I believe 98's) require either a speedo gear or a speedcal. Tuners will NOT change the speedo on them.
*edit Ahh to hell with it, here's ya a link: The t-45 is slightly different than the t-5.. like I said, the 23 tooth was still way off for me.. its listed on here as for 4.10's but on jegs and the brothers performance site it lists it as for 3.73's with a t-45. http://www.steeda.com/products/speed...tion_gears.php
