my gt vs ls1 camaro
RE: my gt vs ls1 camaro
it takes a 01 motor + timing adjuster, exhaust(STOCK headers) pulleys, 4.10 gears, and a few unneeded things (spare, rear seat) removed, to get a 13.2 on street tires, 12.9 on dr's
so you need a bit more
editted for those of you that misunderstood
it takes a 01 motor + timing adjuster, exhaust(no headers) pulleys, 4.10 gears, and a few unneeded things (spare, rear seat) removed, to get a 13.2 on street tires, 12.9 on dr's
I really dont want to start to tell u how wrong u are. But for starters why would he need an 01 motor. The 99-04 is basically the same thing. With small exceptions. The non pi GT's are basically the same except for the heads and intake. And a timming ajuster would really only be needed if ur running n2o or major boost. Running open headers on Modulars will reslut in bad things such as buring up the exhaust valves and they will cause u to lose power. And im not seeing without suspension 12.9.
im not spreading lies, im using an example, (my car) and when i say no headers, i mean stock headers.
and from what i understand 99-04 are all the same, except late 01 they changed clutch size and waterpump pulley.
Yes, i know what u ment. Its cool to start her up with just shorites (factory ones) in the gargage. Hell we did it when we put on a prochamber to my buddies 02 gt but u will be losing power down low, becasue of the lack of backpressure. And i personally think it dosnt sound that good unless ur over 350 CI. A buddies Lt1 camaro sounds bad *** with just shorite headers. But hes changing them to LT's with dumps.
yeah, i dont frequent car forums too often, but im trying to get in the rythm of hitting them up a bit more.
although i did go around town one day after unbolting after teh x pipe before the mufflers .... i got to play nascar ^^
ORIGINAL: trance565
ORIGINAL: HaV
it wasnt that they changed the clutch size on the motor man.. its they changed the transmission/housing/clutch splines. The 4.6 from 99-04 are all basically identical.. and the cars still put the same power to the ground.. ford just switched to a newer tremec.
ORIGINAL: trance565
