Engine keeps stalling!
RE: Engine keeps stalling!
good luck dude, side note did you take off the whole pulley assembly and the face to do your cams, or were you able to unbolt the sprocket and all that to do the swap. I know how it should be done but thats my question. I have experience with shortblock chevy motors and I know all about what cams to get yadda yadda I just want to know about the intall but not so much the mod block let me know
ORIGINAL: sitnlopro99gt
you should check the voltage of the TPS at idle (make sure you do this wile the car is off) but at idle the voltage should read .98 and at WOT it should read 5 volts if its off at idle you need to set it by unscrewing the TPS and moving it around untill you read .97-.98 volts
I had to crack the TB to get my **** to idle right with the new cams. You only need like a half a turn on the adjustment screw. If you adjust it too far, then you end up having just a really high idle. I also had to add 10% to all my idle air values in my tune to compensate for the cracked TB. Why did your tuner set the idle at 600? Should be at like 850.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
