They won't work in NPI heads without modification to the spring pockets and or some offset retainers. It can be done but if your gonna take your heads off to be modified to run an aftermarket PI cam you might as well get them ported also.
How, then, are people able to swap the PI cams into a NPI head with no clearance issues? People do the PI cams/intake swap often without swapping heads.
stock pi cams are very mild and don't have as high a lift as the VT PI cams...
