tb/throttle cable sticky?!
Old Dec 10, 2006 | 09:20 PM
rvoss5's Avatar
rvoss5
Default tb/throttle cable sticky?!
so as some of you know i installed a new 75 mm tb and intake plenum. here's the thing. when my car is turned off, the throttle cable is not sticky/stuck. when i turn my car ON it sticks like crazy when i let off the gas. anyone have a clue what is wrong? thanks!
Old Dec 10, 2006 | 10:00 PM
rvoss5's Avatar
rvoss5
Default RE: tb/throttle cable sticky?!
anybody else have this problem? anyone?
Old Dec 10, 2006 | 10:03 PM
ZW99GT's Avatar
ZW99GT
Your TPS is muffed. That would be throttle Position Sensor. You may have put it on wrong. Possiblility.
Your TPS thinks your throttle is being pushed when its really not.
Old Dec 10, 2006 | 11:05 PM
rvoss5's Avatar
rvoss5
it actually happens when i let off, and the throttle closes, if i'm moving or at idle, when the throttle is closed you gotta really press on the gas to make it pop loose again.
Old Dec 10, 2006 | 11:06 PM
trance565's Avatar
trance565
on the topic of tps, is that the little grey tube thing thats on the throttle (for lack of better word) lever?
Old Dec 11, 2006 | 12:08 AM
ZW99GT's Avatar
ZW99GT
Ohh, ok. I didnt get that the first time. The blade inside the TB is just stuck. Take it out and make sure there are no rough edges or anything like that. It should be a tight fit, but not sticky
Old Dec 11, 2006 | 01:00 AM
rvoss5's Avatar
rvoss5
how do i do this?
Old Dec 11, 2006 | 01:06 AM
ZW99GT's Avatar
ZW99GT
If its not too much trouble take off the TB and look inside at the little disc that turns when the throttle is pushed. Something on that is catching I bet. Did you guy this new?
Old Dec 11, 2006 | 01:29 AM
rvoss5's Avatar
rvoss5
yes. the thing is, is when the car is off, it is not getting stuck. for some reason it also whistles really bad. i wonder if the tps could make it act stuck like this or wtf is wrong with it. i've had it apart 3 times and can't figure it out. it's driving me nuts.
Old Dec 11, 2006 | 01:55 AM
Tapeuup's Avatar
Tapeuup
I ♥ Acer
I have read that the butterfly is being sucked shut and people have drilled a small hole in the butterfly to allow it to relieve the vacuum/suction and open. I have never tried this or had this issue.
