electrical problems
Old Dec 14, 2006 | 11:38 PM
mach1197203's Avatar
mach1197203
Default electrical problems
I ahve a 96' gt that is having major charging problem. I have gone through and replaced the battery and the alternator along with the belt. soem days it like's to work fine, some days it dosent want to charge for nothing. when it is acting up if I let it run for a while it will usually start working fine again but it's hard to know how long it will last. I have checked the ground on the core support but cant find where the main ground wire goes to. also I have noticed that the coolant seems to gel up on the temp sending unit as if it has an electrolosis problem( the coolant was changed out about a month ago). this is a first gen intake that I am waiting on to crack at the front ( known problem), could a main ground problem be causing this? Also I have checked all the fuse's inder the hood and the dash and the fusible links and I have replaced the plugs on the back of the alternator that where cracked. anyone have an idea????????????????
_____
/______\
l [[[ o ]]] l
\_o__o_/
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
