Should I get a custom tune or a Programmer?
My car is a 2003 Auto GT w/ 70mm TB, Plenum, K&N Filter/Silencer Removed and March RAM AIR, SLP LM1's w/ Pypes OR/X and Steeda Pulleys..
Is it in need of a "Custom Tune" or Can I just get a Predator to adjust the timing/shift points?
You don't need any of it really. If you're going with a tuner, go with SCT Xcal II. Predators are worthless. If you want to adjust shift points, buy a B&M Shift Kit.
predators are not worthless, depends on what your local tuner uses... SCT and Diablo do the exact same thing, but get a handheld, more useful, and hold mulitple dyno tunes
a handheld tuner will fix the prob. of runnin rich due to your o/r midpipe. itll give you a few options that will give you about 5-10hp. ive had both diablo and sct. personally theyre both the same. just different technology, and really find out what you local shop has and stick with there software. itll save you money in the longrun.
dont expect much from the tuner though.
Sep 1, 2015 08:16 PM
