SVT Forums
Gas building up in throttle body
Old Sep 12, 2015 | 01:01 PM
TorinoCobra070's Avatar
TorinoCobra070
Chikn Pharmr
Default Gas building up in throttle body
Hey everyone. I have an 04 Cobra, posi ported, supporting bolt-ons, custom tuned. It's always had a little trouble starting after being run and parked a short time on hot days. Well this time it finally stumbled and cut out completely. Very strong gasoline smell. I let it sit 24 hours, still wouldn't start. I start looking into it and trace the gas smell back to the throttle body. I opened the throttle and gas is just built up in there and comes pouring out.
Edit: The car was running perfectly fine before I turned it off. It sat outside in the hot sun for about 45 minutes and then wouldn't start.
Since then I did manage to get it started once, and it was running very rough, so I cut it off. It hasn't started since.
I've searched but can't find any suggestions on what the problem is. Any ideas?
Thanks in advance, and sorry if this is poorly written. I'm posting from my phone.
Old Sep 14, 2015 | 01:06 PM
TorinoCobra070
Chikn Pharmr
Bump - I take it from your silence that this is very, very bad and nobody knows what is going on.
Am I going to have to take it to a professional shop to diagnose?
Old Sep 14, 2015 | 04:21 PM
jwog666's Avatar
jwog666
its just an unusual concern, fuel really has no way to get into the tb as the injectors are pointed at the intake valve. are u sure that its fuel? or could it be moisture, or engine oil/blowby being drawn into the intake through the pcv system. alot of people run an oil separator to prevent this.
Old Sep 15, 2015 | 01:30 PM
TorinoCobra070
Chikn Pharmr
Unfortunately it is most definitely gas. It is enough volume for me to be positive of that, which makes it all the more concerning.
Old Sep 15, 2015 | 01:50 PM
Derf00's Avatar
Derf00
Gentleman's Relish
The only way I can think of fuel working its was back through the TB is if you have an intake valve that is not fully seating itself and is getting fuel pushed back through it on the compression stroke. The odd idling before it shut down completely is also making me think this.
If your PCV system is getting that much fuel into it , your oil would be the viscocity of water and reek of gas. Not to mention you would be getting a lot of blow-by (smoke).
Run a compression test and then if you find something, a leak-down test to pinpoint the source of compression loss. My guess, intake valve(s).
Old Sep 15, 2015 | 02:28 PM
TorinoCobra070
Chikn Pharmr
All the symptoms fit, other than I have not changed the oil - which I know I need to do ASAP after fixing this problem. I did have one other person suggest that intake valves could be the suspect.
I'll do the tests you suggested and go from there. Thanks for the feedback.
Old Sep 18, 2015 | 08:55 AM
TorinoCobra070
Chikn Pharmr
Bump for further advice.
Hey guys, I am going to check the injectors first on the advice of a few people. If this is the problem, what other maintenance should I do since gas has possible been sitting in the cylinders?
I know I need to change the motor oil. Do I need to pour a little oil in the cylinders manually before restarting the car?
Should I change the supercharger oil as well? Do I need to remove the supercharger completely for any reason? A friend said maybe I should pull it and let it dry out since gas backed all the way through it as well.
Any other precautionary steps I should take before restarting the car?
Thanks again everyone.
Old Sep 18, 2015 | 09:48 AM
jwog666's Avatar
jwog666
just change the oil, forget the oil in the cylinders as long as it isnt flooded, the supercharger oil is not exposed to fuel so thats good to stay. dont pull it off.
Old Sep 18, 2015 | 10:34 AM
TorinoCobra070
Chikn Pharmr
Fantastic! You saved me quite a headache. Now I just need to cross my fingers and pray it is the injectors not the valves.
Thanks.
Jb145700
Aug 21, 2022 06:37 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Webster454
Sep 7, 2015 04:59 AM
5.0 kevo
Sep 3, 2015 06:24 PM
