dtc 5284 code for dan cobra
Old Dec 18, 2006 | 02:48 PM
redgt2000's Avatar
redgt2000
Default dtc 5284 code for dan cobra
alright, i got the dtc5284 code ,failing oil pressure switch, is this bad, what do you do to correct it?
Old Dec 18, 2006 | 02:54 PM
99GTvert's Avatar
99GTvert
is my username.
Default RE: dtc 5284 code for dan cobra
do you have a handheld scanner or did you use the test gauge thing on the dash? and also was the car on?
Old Dec 18, 2006 | 03:23 PM
Dan04COBRA's Avatar
Dan04COBRA
Don't sweat it. Ignore it. [8D]
Old Dec 18, 2006 | 07:26 PM
redgt2000's Avatar
redgt2000
alright, now my oil guage was going all wacky, jumping from zero to normal then back but my engine and oil pump r brand new, the oil sender unit thing was the culpret, i just replaced it today, had to go to ford for the part all of the car "zones" part stores had this crazy bolt/nut looking one that diddnt fit, mine needed a clip, ford fortunatly had one i put it in today, and now the guage needle works perfect, . so that code basically gets tripped cause when you start the test, your car if off, and there is no pressure, tripping the code? jw thanks dude for all your help , dan04cobra for president!!!!
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dathan
Oct 5, 2015 05:52 AM
