mach 1vs. cobra
mach 1vs. cobra
i read in a magazine that the mach 1 is suposed to run 13.1 bone stock with 305hp. in the same mag they said that a 03/04 cobra runs 12.7 best...i also read that they run 12.9. they both have 4v motors but why is the cobra only .4 faster than the mach 1 when the cobra is supercharged? does the supercharger not do much?
RE: mach 1vs. cobra
The Mach 1 has 45 hp more than a GT but they are supposed to be underrated. The Mach 1 has a solid rear axle like the GT so it is considerably lighter than a Cobra(IRS) and thus easier to launch. That said didn't MM&FF run a 12.4 or so with a stock 03/04.
RE: mach 1vs. cobra
Drag radials with 0 other mods, 03/04's are capable of a low 12. Won't see it often. You also won't see Mach 1's running low 13's 100% very often.
The Mach 1 is a GT with a 4v engine. Same HP limitations. It's definitely NOT a smarter car to buy to make big HP & get down the track, if that's where you are planning on going with this.
RE: mach 1vs. cobra
nah i was just reading and i was a bit confused so i figured id ask. there was a guy at the track the other day with a supercharged mach 1. he said he was runnin 8psi and made 450 rwhp. he was only running 13.0 tho....was he just a bad driver?
RE: mach 1vs. cobra
haha this is true
and those mach 1's are fast my buddys hit 12.9 stock so they are def nice cars but the o3/04 cobra will rape one, i would rather have the mach b/c i personally like n/a cars better but i luv the 03 cobra
ORIGINAL: Dan04COBRA
If he only ran a 13, he better be at a track in Denver Colorado or have completely bald tires. Otherwise he sucks at life.
breaking
10-02-2015 01:27 PM
