Spark Plug Blow Out Question
Luckily (knock on wood) this has not happened to me, but it scares the sh_t out of me. Can anything be done to prevent this besides making sure they are tight every so often? I don't want to torque them down too hard for fear of jacking the aluminum threads. How tight would you have to crank them to screw the threads up?Anybody have any tips on this?
RE: Spark Plug Blow Out Question
Just make sure you're running the new Motorcraft plugs - AGSF-32C (copper or AGSF-32P (platinum). The old plugs were the AWSF-32's and they got redesigned with more threads and a larger shoulder for the plug to bite into in the head so they stay tight.
no, not wrong! please explain how to get a 10 tpi screw in a 8 tpi hole? you would have to change the threads in the head to do any good. You just can't add threads to a plug... it won't fit.
ORIGINAL: Tapeuup
Go here - http://www.bullittarchive.com/WebHel...ittArchive.htm click on "Mustang Maintenance" then the first topic is about the AGSF plugs.
