headlight problem - Need Help!
Old Dec 20, 2006 | 10:09 AM
5speed's Avatar
5speed
Default headlight problem - Need Help!
Well this morning when I went to start my car andmy headlights would not turn on. Here is the situation, when I pull the headlight **** outone click, the side turn signals and fogs light up,but when I pull it to the second click,the headlight position, the headlights do not turn on and the fogs turn off and my hi-beam (brights) light turns on the dash. Has anyone encountered this problem? Could it be a blown fuse? Any help would be appreciated. By the way, I put new Luminics white light bulbs in a few months back. Thanks!
Old Dec 20, 2006 | 10:12 AM
BoanHed's Avatar
BoanHed
Default RE: headlight problem - Need Help!
High beams burnt out maybe???
When you flip your brights, do the fogs come back on?
Old Dec 20, 2006 | 10:17 AM
contentsunderpressur's Avatar
ORIGINAL: BoanHed
Yea, I've changed a lot of these switches. There bad about goin out. Just pull the switch out, unplug it and look at the back of it. You'll know if it's burnt up.
Old Dec 20, 2006 | 10:37 AM
5speed's Avatar
5speed
switch or fuse?
Old Dec 20, 2006 | 10:38 AM
5speed's Avatar
5speed
ORIGINAL: BoanHed
Just checked...when I flip the brights on the fogs still stay off
Old Dec 20, 2006 | 11:10 AM
5speed's Avatar
5speed
anyone?
Old Dec 20, 2006 | 11:13 AM
monkeydude3's Avatar
monkeydude3
sounds like the switch to me, I'd take it out and have a look
Old Dec 20, 2006 | 11:58 AM
96cobra10101's Avatar
96cobra10101
Switch, need a new one.
Old Dec 20, 2006 | 03:08 PM
5speed's Avatar
5speed
Thanks guys. I bought a switch at lunch. Is it difficult to install?
Old Dec 20, 2006 | 07:58 PM
5speed's Avatar
5speed
ORIGINAL: 5speed
Well I installed a new switch at the suggestion of you guys with no luck. I still have the same problem as I discussed earlier. Anyone else have any ideas?
