car hard to start.
ABOUT 2 MONTHS AGO MY CAR STARTED TO BECOME HARD TO START AFTER SITTING ALL NIGHT AND A CHECK ENGINE LIGHT CAME ON. IF THE CAR HAS BEEN OFF FOR AN HOUR OR LONGER IT TAKES ABOUT 5 SECONDS TO START AND SOMETIMES SERVERAL TRIES TO START IT . I TOOK IT TO THE DEALER AND THEY SAID THAT MY PCV HOSE HAD A CRACK IN IT, AND THEY REPLACED IT AND THE CHECK ENGINE LIGHT WAS RESET.IT STARTED FINE THAT DAY ,BUT THE NEXT DAY IT WAS BACK TO THE SAME OLD CRAP.I READ ON THIS FORUM THAT IT COULD BE A DIRTY MAF OR DIRTY FUEL FILTER SO I CLEANEDTHE MAF WITH MAF CLEANER ABOUT 2 WEEKS AGO AND NOTHING CHANGED.2 DAYS AGO MY MIL CAME BACK ON.I CHANGED THE FUEL FILTER AND CAR IS STILL HARD TO START. TOOK IT AUTO PARTS STORE AND GOT MIL CODES 1132 AND 1152 BOTH ARE O2 SENSOR CODES FOR A RICH READING ON THE NO1 AND NO2 BANK SO I THINK THE O2 SENSORS ARE WORKING BUT WHAT COULD BE CAUSING MY CARS RICH CONDITION AND COULD THIS BE THE HARD START UP PROBLEM I HAVE INSTALLED A NEW K@N FILTER AND CAR HAS NO DRIVABILITY ISSUES PLEASE HELP THANKS . PS. BATTERY TESTED GOOD.
Problem start after the MAF cleaning? I would check for a leak or hose off after the MAF which would allow unmetered air into the system. That would cause a lean condition. Thta's where I would start. Be sure everything got plugged back into the intake tube and such. Mark
ORIGINAL: gray ghost
today changed fuel filter, air filter clean, car is hard to start when cold,sometimes when car is hot it is also hard to start. later today the check engine light came on, took it to auto shop and had it scaned, codes p1233,p1132,p1152 came up all three codes indicate 02 sensor problem, the mass air flow sensor was clean two weeks ago with crc brand mass air flow sensor cleaner. car has no drivability issues, other then being hard to start. my question is how do I track down what is causing the 02 sensor to tirgger the check engine light. could it be the EGR. please help thanks. 02 GT.
What do mean "hard to start?" Elaborate.
Usually when you post something like "I just cleaned the ... two weeks ago the "..." needs to be replaced. Why would you clean the MAF? Some things on your carneed not be ****ed with.
You may need a craw foot to replace your o2 sensor, idk. Depends on your tool selection and the amount of room you have under there.
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
'stangdude
Aug 12, 2015 01:27 PM
