I need a link to a fuel pump!!!!
RE: I need a link to a fuel pump!!!!
When I decided to go for 500+ rwhp, my tuner said the safe way (for fuel delivery) was to upgrade to the Cobra tank/pumps. He said that no aftermarket GT pumps would do the job reliably. It was expensive ($1200), but worth it for the reliability.
I have the KB Boost-a-pump too.
$1200? Wow you got jacked. I paid $566 for everything on mine. Used tank and brand new fuel pump unit(changed to svt pumps) I kkow the list for each is like $600 plus. but you've got to shop around before buying anything. You can ALWAYS find it cheaper elsewhere.
I recommend you just go to the Ford Dealer ship.
Tell them you want a single fuel pump for a Ford GT.
Other options include: SVT Focus, or Lincoln Aviator. I'm sure there are others but these are pumps that I KNOW will work.
It'sa straight forwardinstall, drop the tank (make sure it's practicallyempty), disconnect the wires, fuel lines, and the thing coming from the gas cap.Take the basket out, remove the pump, put the new pump in, and put it all back together.
ORIGINAL: mikev08826
Focus pump are good to about 450 rwhp. I don't think the fp is your problem though.
ORIGINAL: ZW99GT
What is my problem? I didnt think I had a problem yet. This is for when I'm spraying
Just some extra help if you go with one.
ORIGINAL: ZW99GT
my bad
ORIGINAL: stang2000
Regardless, if you want to put 550+ to the ground, the safe way is with Cobra tank/pump.
mrappe
09-26-2015 10:16 AM
