I know they don't do anything but I like how it looks and for now the the engine is stock so I really don't need one but my parents got me one so I will put it in.
What I did was go to raptorperformance.com and look up the installation instructions on how to install there shiftlight. Follow those directions until you get to the wires. Now I forget exactly which wire it is b/c there is a couple hundred, I do know that it is black and red. I'll get the exact wire for you in a minute.
your best bet is to tap into the PCM under the passenger side kick panel. The red wire goes to 12v ignition, white wire goes to dash lighting, black wire goes to ground, and purple goes to o2 sensor source. At the pcm, it's Pin number 87, red w/black stripe or Pin number 60, gray w/light blue stripe. Very simple to do.
