Electrical Problem
Old Sep 14, 2004 | 03:54 PM
SXGT's Avatar
SXGT
Default Electrical Problem
My dash lights dont come on. When i turn my head lights on my center clock goes really dim. I checked all teh fused under the dash and under the hood. I looked and all the bulbs are fine. I may have over looked the fuse for the dash lights, where is it located , anyone have a fuse map?
Old Sep 14, 2004 | 04:03 PM
SilverGTV8's Avatar
SilverGTV8
Default RE: Electrical Problem
is the light intensity **** turned all the way up? If it is turned down then every thing will be super dim or appear to be off.
StangMang's Avatar
StangMang
pretty sure they're under the hood
Old Sep 14, 2004 | 04:21 PM
SXGT's Avatar
SXGT
HMmm maybe my dimmer is brken! that makes the most sense , when i turn all the way over my dome light still comes on how ever. Ill mess with the dimmer some more.
Old Sep 14, 2004 | 04:34 PM
StangMang's Avatar
StangMang
ya i bet thats it if the dome still comes on when it clicks all the way to the right
Old Sep 14, 2004 | 04:38 PM
SXGT's Avatar
SXGT
well i took the entir dimmer thing out and its work good to me , nothing apears to be wrong with it.
Old Sep 15, 2004 | 12:54 PM
roundman's Avatar
roundman
did you check it with a ohm meter to see if the resistor is still good or burnt in two? there is a separate fuse for the dash lights, look at the cover plate for the fuse panel, this usually identifies which fuse goes to what circuit. it could also be corrosion on the contacts in the dimmer switch, get some electrical contact cleaner spray from Radio shack and use it on the dimmer switch while rotating it back and forth to clean the contacts in the switch.
jma2
Jul 10, 2023 01:00 AM
ak98
Feb 18, 2023 08:36 AM
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
