Missing HP...
So, I got my dynorun with my new setup and on the dyno I only gained 28 RWHP. It was running a bit rich, the guy said 3% rich, but I only put down 289 RWHP. I couldn't tune it right then because my SCT wasn't powering up, but I eventually fixed the problem. Anyway, only 28 RWHP with the following changes (on the same dyno as before):
Stock PI heads to ported PI heads
Comp stage 1 cams to Comp stage 2 cams
10.5:1 compression to 11.5:1 compression
BBK shorties to MAC long tubes
H-pipe to Prochamber
Stock T/B to 75mm T/B
Stock plenum to C&L plenum
87 octane to 91 octane
Canton windage tray
261 RWHP to 289 RWHP (running a bit rich)
Tell me if this sounds right. Keep in mind that this was done at 2600 ft elevation, 55 degrees and not sure the name of the dyno.
Canton windage tray
Ya, I took it back 4% because the tuner would only to 2 or 4%, not 3%. The guy said I should go over 300 RWHP with the a/f corrected. I just figured after all those mods I would pick up more power than that. Oh well, I guess real dyno hp is not even close to advertised hp.
Matt's 95 Stang
Oct 5, 2015 07:16 AM
breaking
Oct 2, 2015 01:27 PM
