compression ratio
Old Dec 29, 2006 | 04:41 AM
Quick Shot xMLx's Avatar
Quick Shot xMLx
Default RE: compression ratio
ORIGINAL: 2000GT4.6
I don't know how that one website managed to do it, but everyone quotes them and thinks its right lol. Like I said though, a bigger combustion chamber, the same pistons/crank/rod, and a higher compression ratio? Wtf?
Thanks you just crushed my dreams of my 02 being a factory freak[:@]. Damn I knew that the LS1 I raced couldn't have been trying
I've been living a lie all my life
Old Dec 29, 2006 | 05:05 AM
2000GT4.6's Avatar
2000GT4.6
I have been around a few factory freaks, worked with them everyday that is. When you have to hire at 9 bucks an hour you don't always get the best help around here
Old Dec 29, 2006 | 03:15 PM
droptoppony's Avatar
droptoppony
ORIGINAL: Quick Shot xMLx
Didn't they bump up the compression a slight bit after 2000 or so?
After researching about other forced induction cars(DSM,Evo, etc) 8:5 or somewhere around there is a good number. No need to go higher and make the engine make power, that's what boost is for
I've seen some 9:x forced induction builds before and it seems a bit silly. They are often limited to the amount of boost they can run. Don't you gain something like 4% power for every full compression point? Might as well go low and be able to run more boost.
Those cars need lower CR's because they are running Turbo and lots of boost...Usually with a Turbo or Positive Displacement Blower you will want to bring the compression down in the mid 8's so you can run more boost and make tuning easier. With a Centri haveing a comression ration @ where the stock c/r is now is very good.(9.3-9.4) It allows the engine to make some power down low before the boost kicks in.
The 03/04 Cobra has a C/R @ 8.5 but thats a PD blower setup...
Old Dec 29, 2006 | 04:01 PM
rbstang's Avatar
rbstang
9.4:1 compression
Jb145700
Aug 21, 2022 06:37 AM
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
