ABS
Old Dec 29, 2006 | 01:41 PM
idcoocheimonster's Avatar
idcoocheimonster
Default ABS
So, now and then, my ABS light will come on, turning of my Traction Control. Thing that sucks, is that it usually happens at the worst times. In pouring rain, or when streets are still moist from a down pour. I checked the brake fluid, everything is topped off. Any idea on what could be causing it to go on and off. It started out about once a month, now its up to about 3 times a day, where it goes on for about 20 mins, then back off. Please help, and thank you in advance.
Old Dec 29, 2006 | 09:13 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: ABS
You probably have a bad ABS sensor.
Old Dec 29, 2006 | 11:20 PM
kylebgt's Avatar
kylebgt
Default RE: ABS
Better check your blinker fluid
+1 to the post above mine. Have you tried reseting your ECU?
Old Dec 29, 2006 | 11:22 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: ABS
Probably a bad sensor like posted above. I have to take my ABS bulb out because I am now ABS'less.
Old Dec 29, 2006 | 11:41 PM
dothack's Avatar
dothack
Default RE: ABS
Same here..what I did and it work last time. I clean every sensor with carb cleaner..and it work for a while. Now the damn ABS stays on..I think its a sensor gone bad. I read those things are expensive. Is the ABS is really necessary? When it rains, I drive carefully...very rare my tires lock up on me...I should probably spend the money in some other engine mod than damn sensor lol
ThatJuanStang
Sep 25, 2015 08:01 AM
MonsterBilly
Sep 19, 2015 08:50 PM
gagemcc
Aug 26, 2015 12:37 AM
HillbillyLambo
Aug 21, 2015 10:07 PM
Daleford
Aug 10, 2015 08:30 PM
