Possible to make scoop function as ram air?
Would it be possible to turn the stock scoop on my hood into a functional ram air? I figure if I could get something made that runs from the hood to the airbox, I could do it. Also, how would I avoid water in my intake with this? How is the mach ram set up to avoid water?
RE: Possible to make scoop function as ram air?
With a hood that has enough height, maybe. But, you wouldn't be ramming the air into the intake, just porviding cooler air.
I have the March Ram Air system and it does help. Unfortunately, the scoop is under the bumper and makes for a heck of a road cleaner....same would the true for Aixtreme. The hood mount would be nice...good luck fabbing that one.
I figured it would be hard to fab it into the current scoop. I would like a functional scoop, but they are $800 for the parts without hood or labor. Maybe I could get a mach hood and scoop from a crashed mach.
Sure its possible. But the problem is thats very restrictive to make it in the location of where the fake hood scopp is... You will have to make a complete 180degree turn and back to the stock air box. That is very restrictive. If your going to try it, I would suggest getting a hood from a junk hard and practice on that. Also alot of the air goes over the hood and wouldnt go into the hood scoop. But I would love to give it a try if I had another hood to cut up.
As for my ram air picking up road crap, it probably will some what, but I still have the filter on of course. So that will help catch most of the crap, I will clean it regularly. The March ram air makes you locate it alot further down, below the bumper, mine is in the bumper, about 7" off the ground.
I had my car setup with ram air going through the factory scoop.Aixtreme beleive me plenty of air goes into the scoop I had to replace my hood because it became a pain when i couldnt go over 70mph before my scoop would tear of my hood.Thats right 6 bolts and it still tore off. If you would like i could take pics of it and post it for you guys.
ORIGINAL: 99mustanggt
