what is lobe separation
Old Sep 19, 2004 | 10:58 PM
quarterhorse's Avatar
quarterhorse
Default what is lobe separation
hi i was looking at the lobe separations for my cams. i noticed that the stock lobe separtion is 117 degrees. mine is 112 for stage 1 aftermarket cams. i was wondering what the lobe separation means and would i have to shim the lifters. i need this info bad so please help me
Old Sep 19, 2004 | 11:03 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: what is lobe separation
Lobe separation is the distance between the intake and exhaust centerlines. Closer lobe separation means more overlap - meaning more lope at idle and a higher powerband. It has nothing to do with shimming the lifters, you should only worry about that with re-ground camshafts or anything that has a cam base circle smaller than stock. Most aftermarket cams you shouldn't have to worry with this - but all experienced engine builders check this reguardless.
Old Sep 20, 2004 | 01:41 AM
S_man_9's Avatar
S_man_9
what mdvaldosta said. It is the length in time when both the intake and exhaust valves are open. A lower LSA (under 110) will be more for a high revving motor while a 112 and up would have good idle quality down low. Id say a 112 is a good all around LSA. Hope this helps.
Old Sep 20, 2004 | 10:09 AM
quarterhorse
thanks for the info finally got my pic up
[IMG]local://upfiles/5212/ED2EBD234C1943FBBDABCB1B441506CE.jpg[/IMG]
robcy
Suspension
Oct 27, 2015 11:14 PM
breaking
Oct 2, 2015 01:27 PM
UrS4
Sep 30, 2015 10:13 AM
vbonina
Sep 22, 2015 08:31 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
