SLUDGE ALREADY?????????
My engine has less than 10000 miles. I changed my oil two weeks ago, with mobil 1. I just checked it today (just for the hell of it) and it was DIRTY. Not really really bad, but it was terrible for 400 miles and 2 weeks. Can I have sludge in there already? Do I need to flush it? WHAT DO I DO??????? This is really getting on my nerves.
RE: SLUDGE ALREADY?????????
Just because oil is dirty doesn't mean it is time to change just like mustnglvr said it is just doing its job and with a good filter a syn. motor oil can go for 3k + but to each his own, no need to be worried. Now if there was some kind of irregular color I would worry. I personally use mobil 1 and change every 3k or 6 months.
What color is the oil?
This is what would scare me about buying a heavily modified car without knowing the person, it just doesn't make much sense as to why they would be selling a nearly complete build with a huge investment and a lot of time & effort put into it.
It's typical for a hi-po car to tan oil quicker than a stock engine, but if the oil is looking thicker than it was when you put it in, or if it's black then you should flush it. Maybe you can do an oil change with conventional, run it for a couple days and change it for synthetic again, see if it cleans itself out a bit if you don't want to flush it.
ORIGINAL: sitnlopro99gt
ORIGINAL: Dan04COBRA
It's not so much the oil that needs to be changed @ 3k, nor the breakdown of it's viscosity, it's actually how dirty the oil gets. So yeah, if your oil is getting rather dirty less than 1k into an oil change, it's a good idea to change it and get down to the bottom of the problem.
ORIGINAL: ZW99GT
Sludge is a product of the reaction between the acid,water,carbon and dirt that goes through an internal combustion engine.
For all the info you could ever want about oil check out the link in my sig.
The seconda honda civic with a front end confersion I did myselfwith a built soch motor some guy just came up to me and asked me if I would sell it..so I did andit wasnt even finished???
Sorry for the off topic post.. I wouldnt stress tomuch about it man..
