Turning O/D off?
RE: Turning O/D off?
yeah , the stock O/D band sucks . so dont do any WOT 4-3 or 4-2 shifts either . I've seen 20% torque reduction on shifts still kill the O/D band . the rest of thestock 4r70wis good for500hp w/ a shift kit .
the stock 4R70W will not shift into OD at WOT from the factory, turning it off just locks the car out of overdrive, i turn mine off if im going less then 50 mph so it doesnt bog, turning it off does nothing for preformance, if you want a preformance technieque, about 400 rpms before the redline in first gear, pull the shifter back to the "2" postion, this is known as the D2D shift and is programed to firm up the 1-2 shift on fords 4R70W auto trannys, i can chirp the tires in my stock split port by doing it
OD is designedto be turned off if roads are wet or icy! The car has more grabbing power and control with OD off in these situations. Turning OD off in normal driving just uses more gas as you're in a lower gear (3rd), but the exhaust does sound much better!
ORIGINAL: blstoff
I could leave it in drive & chirp 2 when it was all stock . there is different shift pressure for manual shifts . I have SCT advantage software so I can see all the paramitters . the stock tune reduces torque onALL shifts .
