somethings wrong!!!
somethings wrong!!!
I think something is seriously wrong with my 03 gt... everytime i hit the brakes when im going between 50 and 65 mph, my steering wheel shakes a lot... this has been going on for a few weeks... and nowwhen i just drive between 60 and 65 mph, the wheel shakes a little... what could be wrong. one of my friends said he thinks my brakes might be warped but why would it shake when i dont hit the brakes... and if im going over 65 and less then 50, thee is no shaking at all... i have no idea...
RE: somethings wrong!!!
Its your rotors buddy. Goto Advanced, and buy pre-cut rotors. Slap them on, and problem solved. Basically the heat warped your rotors, and they are uneven now. If you have a manual downshift more often when comming to a stop. If you have an auto theres not much you can do.
you brake rotors are warped.. time for some new ones
EDIT: also.. make sure the lug nuts are torqued down to the specs right for the vehicle.. if not, that can warp your brake rotorsover time...
i had this happen to me but i only noticed it when i was at the track braking at 100+. But i got new rotors and boom everything seemed fine. So yeah just like everyone else said its probably your rotors.
time for new rotors. it might even be your tires. are they rated for high speeds? thats what happened to a buddy of mine. right when he hit 60 it started shaking bad. but im pretty sure you'll need new rotors.
my tires are z-rated so i dont think its them... im gonna try changing my rotors and see how that works... i really hope its not tie rods or anything else with my suspension cause that could get expensive... any i dea how much new rotors cost???
