lowering
Old Jan 12, 2007 | 08:35 PM
quitbichyn's Avatar
quitbichyn
Default lowering
what kit does everybody recommend? around here the eibach pro kit is pretty common. i dont really know jack about suspension, is there anything other than the kit itself i need to lower the car like control arms or cc plates?? by the way i drive a 03 gt auto and when i go to drop it i will have 410's in and a s/c after the suspension.
Old Jan 12, 2007 | 08:41 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
Default RE: lowering
if you lower it past a certain point (I don't recall, I think it's anything more than a 2" drop) you will need the cc plates to get the front wheels aligned to spec. you may want to replace your shocks and struts while you have everything apart, as they are supposed to go bad faster when you are lowered. control arms are not needed, but they require a lot of the same disassembly to install, so you might want to think about doing all that stuff at once. might need a pinion snubber as well, I used the maximum motorsports with ford C springs and KYB adjustables.
Old Jan 12, 2007 | 08:50 PM
hot wheels's Avatar
hot wheels
i used h&r supersports with maximum motorsport cc plates and tokico hd s/s, don't mean to correct redass but i believe it's anything lower than 1.5 that's why alot of people go with the prokit, simple spring replacement. can't really tell a lot of differance unless you go lower than that, mu opinion. if your gonna spend the money and time you might as well really notice you've done something.
[IMG]local://upfiles/18250/A5B5CFC598B44273922E01255ECB4D66.jpg[/IMG]
Old Jan 12, 2007 | 08:52 PM
hot wheels's Avatar
hot wheels
a good site to see the many differant spring drops out there http://www.2kgt.com/item.php?itemd=74
Old Jan 12, 2007 | 08:53 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
by all means, correct me if I was wrong.
Old Jan 12, 2007 | 09:15 PM
Adam03GT's Avatar
Adam03GT
So if you go with the eibach prokit how soon will you have to change out the shocks and such?
lincolnshibuya
Jul 5, 2020 03:05 AM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Oct 3, 2015 06:23 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
NYstang
Sep 30, 2015 09:56 PM
