Wheel spacers with 9" wheels
RE: Wheel spacers with 9" wheels
Ok...The Law of Physics eh....well, I wouldn't want to break that law. Might you present more of a Mustang Forums answer like, "they make your tires wear outfast" or "I had a friend who's wheels fell off".
I think that they cause the offset of the wheels to be thrown off, causing problems with the rear end, potentially causing the bolts that hold the wheels to the axles to bend. Do a search and you may find something a little better than that. Of course, I could be completely off.
well, the first reason that comes to my mind, is that you have to get MUCH MUCH longer studs in order to use a 1 inch spacer, as a 1 inch spacer leaves you with about .....1/4 inch stud at most. and your wheels are most definantly more than 1/4inch thick
ORIGINAL: trance565
I have 9 inch wheels all around it it looks just fine. I have the replicas from the 2007 Shelby GT500, they look freakin awesome, I can't post a picture because it always says its too big.
I run 275 40 17 all around it it looks awesome.
