exhaust question concerning the o2 sensor...?
RE: exhaust question concerning the o2 sensor...?
The hole is in the muffler and i am just using the problem as an excuse to go ahead and buy a whole new system... so i am basically trashing what i have with the exception of the headers and buying all new and need to know what to do if i wat an o/r performance midpipe in the system for sure... what else do i need?
ORIGINAL: stilllearnin
The exhaust manifold/headers, midpipe, and cat back are all their own things. You can replace them all seperately if you want with only one exception. The only exception is if you have aftermarket LT headers, and then you need a shorter midpipe, but if you're just going to keep stock you don't have to worry about that at all. You don't NEED any other part of the exhaust to add one other than in that case of the LTs. So if you want to just get a shop to weld in a new muffler to replace that old one, then get a mid pipe as well, then you'll be good.
That is exactly what i needed to know thank you so much.. so i can just replace the muffler, keep the catback and get a new off road mid pipe?
Yeah, you don't NEED to replace the midpipe, that's just up to you. I certainly would if I were you because it makes a nice difference. It was certainly enough that I could feel a decent amount more pull, then again, I have a non-PI so it doesn't take much to improve what I already have. It also makes it sound a LOT better when you get those cats off there. If you want a little quieter, even deeper, and less trouble with law (depending on where you are) you can also look into getting a mid pipe with high flow cats on it. That way you don't have to worry about emissions and it will quiet it down a little bit while still allowing it to flow a lot better than that stock mid pipe.
Then if you have the money for it, throw an off road mid pipe on there while you're at it! It'll make it sound a lot better than that stock midpipe you have now. As I said before, I like my prochamber because it's not too loud down low so I can drive it relatively quiet if I NEED to (in the neighborhood at night, around cops, etc), however when I hit it it's nice and loud. Otherwise I'd suggest the H pipe for you because you want the deep sound.
We just wanted to make sure that you knew that you didn't NEED to replace anything more than the muffler to fix your problem. The midpipe will just make it flow better and sound better.
