Tires chirp under LIGHT acceleration...
Ok recently I've noticed my tires chirping more and more. I've been driving the car for awhile and I'm driving the same as I always have, but now I hear the tires chirp constantly. Even with the lightest possible throttle, I hear them. I'm not too worried about them chirping, but I am worried that something might be wrong. I've just got intake/exhaust, my FI comes in bottles, so my car isn't very powerful around town. My tread is good on both sides so I just don't understand why I'm hearing them chirp when I'm practically rolling off the line. Am I just being stupid or is this a bad sign?
It is is a manual maybe just because you've been driving it for a while you have gotton more and more use to it. Like you know exactly know where the best engaugment point of the clutch is where as before you didn't know it that well. My cars engine and exhaust is too loud so i barely notice when i brake loose but, the car started to feel faster and faster as I learned the car more.
ORIGINAL: Brute03
are you sure you're hearing the tires and not something else maybe squeaking?
ORIGINAL: tcuallstar
it is getting colder, which means less traction due to the rubber being colder... that may have something to do with it
If you are sure it's the tires, then I'd say it could be that the tires are cold. That'll make them break loose a lot easier when they are harder.
When you leave a stop light look at the person beside you..if you're like 35 cars in front of them instantly then you know you have a heavy foot and it's probably YOU chirping the tires. If you're right beside them then it's probably because of the cold weather and/or something else. With the cold weather also comes a lossin air pressure so bump them back up to 30-35psi.
ORIGINAL: SVTBill
